mariowar wrote:Judge,
Scale = Cancer on espresso machines.
I understand that resellers of HX and double boiler espresso machines do not recommend descaling due to liability issues.
I had a Brewtus III for 2 years and I successfully descaled ( brew and steam boiler) it every year with Dezcal.
Keep in mind that I refill Culligan gallon containers at Kroger and the water is not only cheap around 30cents /g but it comes very soft at around 5 or 6 ppm, compared to almost 300ppm ( faucet).
Now I have and Alex Duetto II and I just performed its first descaling
I have the feeling that many unsuccessful descaling procedures have been due to users experimenting with high concentrations of citric acid.
Good luck
rbh1515 wrote:Here is what I use in my GS3. I use RO water and add a product from Cirqua:
http://shop.chinamist.com/products/Wate...irqua.html
This is great water for espresso, and it should not cause any scale.
Rob
Dodger1 wrote:I've used a 50/50 mixture of distilled water, with regular tap water, in my Mini II from day one. After 2 years of ownership I descaled it last month and opened up the brew boiler, which turned out to be in pristine condition. My steam boiler is sealed but I did remove one of the fittings, on the top, and took a peek inside with a flashlight but couldn't see any scale what-so-ever.
Chris Coffee suggested that mixture and told me to never to descale it. However, the fine folks at the Vivaldi Cafe have done this and have detailed explanations of exactly how to do it.
FYI, as a general rule of thumb, if you use only straight distilled water your espresso will taste like $#@&.
2nd FYI, you should really get a water hardness test kit, or even the strips that Chris Coffee sells will work, to determine the hardness of your tap water and then the hardness of a mixture of tap/distilled. The key here is that you want to taste the mixture and use the least amount of distilled water you can, while still keeping the hardness within the recommended range.
This webpage http://big-rick.com/coffee/waterfaq.html is considered by most to be the authoritative guide to espresso water hardness.
I am so looking forward to not having to stop at my local Starbucks (no disrespect meant) on the way to work.
erics wrote:Then, change your route and stop here: http://www.cafemyriade.com/
erics wrote:You were given some incomplete and/or incorrect information from the person you talked to about water quality and machine maintenance. It is possible they recommended the use of bottled water and that would be a very reasonable alternative depending on the quality of your existing tap water. A good bottled water to use is Volvic as it has only one source and is bottled there.
erics wrote:As previously recommended, Jim Schulman's "Insanely Long Water FAQ" is available from the Reference section of this site - http://www.home-barista.com/resources.html .
erics wrote:Very reasonable standards for coffee brewing (and espresso) water are here: http://www.scaa.org/PDF/ST%20-%20WATER%20STANDARD%20V.21NOV2009A.pdf
erics wrote:Running titration tests for water samples can be a PITA but there exists high quality test strips from a reputable manufacturer here: http://www.mcmaster.com/#water-test-strips/=cw3pzy%20.%20If%20the%20link%20messes%20up,%20it%20is%20McMaster-Carr%20p/n%2011235T47 .
erics wrote:Then, change your route and stop here: http://www.cafemyriade.com/ . It is one of, if not the best cafes in Montreal. One of the owners wrote these: http://www.professionalbaristashandbook.com/ - perhaps a nice addition to your library.
spiffdude wrote:+1
You might also want to check out Pikolo, Flocon and Cafe St-Henri. All excellent 3rd wave places. I agree with Eric that Myriad is on top.
Back on topic. If you are unsure of how much scale might have accumulated down the road, open up the mushroom and that will give you some indication. Search for "checking for scale on E61 group" or something similar.
