erics wrote:The pressure gage associated with this device is, as far as I'm concerned, of dubious quality at best. Keep in mind that this is one example that I happen to have but still . . . The gage has no name on it whatsoever, comes equipped with a mechanical snubber (ouch) and, for this one example, has about a 10% error in readings.
For some reason most of the Italian manufacturers use a lot of cheap components.
For example on my machine (
Bezzera Ellisse DE 2GR) which is about $5k new they use a cheap $30 pressure gauge.
I understand cost cutting but sometimes it's ridiculous.
Anyway I will relay your observations to the guy in Germany. I asked them to join the thread and post some detailed info and images but obviously they don't care.
erics wrote:The temperature port may be speced at 4.0 mm but that would be a real tight fit. I'm not saying it would not work but you would need to be a little gentle with that particular thermocouple. The temperature gage that was offered with this device (probably an option) is about on the same level as the pressure gage, well, maybe a little worse.
They don't offer a probe with this deal. Anyway the standard K type thermocouple is not good enough.
I have found a local manufacturer that offers pt100 and T type probes with threaded connection on it for about 20€. If I do buy this I will make a thread so I can fit the new probe properly.
erics wrote:Flow is regulated by a ball valve discharging into a standard (?) espresso machine hot water wand end piece. It is a little tough to regulate (as you would expect) but can be done and is a nice feature.
At least something nice about this device
erics wrote:The portafilter base is a standard E-61 and would be a questionable fit on your Ellisse and/or other Bezzera like groupheads.
In summary, save your monies and buy the real thing.
They list this one as bezzera, astoria and brazilia compatible. I will have to ask them for some images and dimensions. This could be a real concern.
As for the "real" thing: Too expensive, my current setup: Bezzera ellise, bezzera grinder both fully rebuilt + some cheap tamper, pitcher etc was about 550€ so I can't justify the cost. Anyway I only need this for initial setup and maintenance of this single machine. Maybe I should just fix my drilled basket and K type probe and forget the whole idea.
