www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
Santa Needs a New Procon Pump!
Postby mspIggy on Sat Dec 24, 2011 12:21 pm
Greetings, Santa Needs a New Procon Pump
Santa has a laurentis machine vintage 1996 that looks allot like this one
Laurentis rejuvination project (moved from alt.coffee)
Pump started to 'hesitate' then would spin and supply water, then finally it simply stopped - it is colpletely seized
Motor seems fine - operates with pump removed
Perhaps one of Santas Helpers may have a pump they wish to sell?
I sourced one locally for a whopping 189.00
Huge thanks
We use this in our flower shop - so this does not get much use - maybe tops, 7 shots a day...
Minneapolis
Iggy
mspIggy
Postby duke-one on Sat Dec 24, 2011 2:11 pm
These are available from multiple sources on the web, check EBay etc. I'd also suggest that you flush out the discharge line from the pump as debris from a failed vane pump could cause trouble after the replacement.
KDM
duke-one
Postby mspIggy on Sat Dec 24, 2011 2:50 pm
Great Ideas...
I am a bit confused however with the nomenclature on my pump reading
Procon C051509L
This C051509L is not 'googling'
what should i be looking for to replace this?
huge thanks
Iggy
mspIggy
Postby mitch236 on Sat Dec 24, 2011 3:07 pm
Despite what's been suggested, I was unable to find a direct replacement on eBay. There is a thread describing how to try to save your pump. I would try that first. There are also less expensive pumps. Search espresso parts northwest. Sorry I can't be more specific but I'm enjoying disneyworld!!!!
mitch236
Postby duke-one on Sat Dec 24, 2011 3:26 pm
Procon does not reconize that number on the search function of their website so call them when they are back in or as Mitch said E.P.N.W. should have it. If you put the "C" next to the "L" Procon has lots of hits. There also should be cross-reference charts from one make to the others but they may all be about the same $.
Good luck and Merry Christmas!!
duke-one
Postby MDL on Sat Dec 24, 2011 4:57 pm
I don't know about swapping from Procon to Fluid-o-tech but you might also contact Fluid-o-tech on the east coast (CT). When I needed to replace the pump in my Vivaldi I was able to order directly from them and save a substantial amount compared to any of the coffee places.
MDL
Postby erics on Sat Dec 24, 2011 5:07 pm
Send the pump here: http://www.jcbeverage.com/index.html - probably about $35-$45. Santa won't have far to travel as they are located in your state.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby mspIggy on Sat Dec 31, 2011 11:47 am
*** WOW ***
JC Beverage -- This outfit turned my pump around "Good as New" and is sending it back to me VIA Speedy Delivery - All of this within them having had the pump for less than 6 hours, and best of all, for under $48.00!
*** WOW ***
Sure does not say much for ESI (espresso services inc) here in Minneapolis who advised me the pump was not serviceable, and then offered to sell me a new series 2 procon pump for a whopping 189.00
When i get this pump back, i will take it in hand to them and show the folks at ESI they have lost a client as i believe they were less than honest with me. There are other parts suppliers here in the Twin Cities -- and i surely will be dealing with them for my future needs.... Too bad, i drive by ESI almost daily and now have a very bad taste in my mouth by their refusal to service my request - Perhaps they should have offered to send it out on my behalf?? Sounds like JC Beverage is a "Supplier" of this sort of equipment and surely ESI is familiar with their industry partners....
Santa is now happy
As to getting this DooDad back into the machine -- How best to flush the lines? and how should i set the Bar Pressure - should i put in a blank or run grinds?
HUGE Thanks
Iggy
mspIggy
Return to Espresso Machines
