I have taken quite a number of pics with my Droid X during the process. I will post them once I get a chance to take them off the phone go through them. I missed a few key shots of the boiler, and HX right after removal and before hand rinse/cleaning. I also missed taking shots of the gunk showing up in the pyrex measuring cup during the flush after the citric acid bath. I was working solo with hands unsuitable for phone manipulation at the time. I will try to shoot a useful set of pics before reassembly as well.
The outside of the HX was pretty clean after the citric acid boiler flush. Just a touch of scale and some black film at the top. It cleaned up pretty easily with a soft scrub sponge. Not sure about the inside, but can't imagine it would be too bad. I've not removed the fittings from the top of the HX. I don't think removing them would improve my access or visibility much.
The boiler had a lot of gunk in it when I first opened it up. Most of it came out with just a hot rinse and a sponge. There is still scale at the water line, but it's not excessive.
The heating element is similar, with just slight scaling remaining. I figure it's worth the extra effort to clean what I can while it's all apart. I won't go overboard with the boiler walls, but I'll make sure to get rid of the scale at the water line. Most likely, I'll go ahead and soak the tubing, boiler, HX and heating element in a stronger citric acid solution, keeping an eye on it.
I'll check for sour salt at Safeway. My first source came from the spice area in Whole Foods. They didn't have a big supply and you buy it by weight. Not cost effective. My second source was from the local brewing supply. They didn't have it in bulk, just in pre-packaged 4tbsp bags. $1.50 a bag. Not too bad, but I've heard tell of getting it much cheaper in bulk.
