Ordered 6/27 by phone. Received 9/23. Extremely well packed. Very dense single wall cardboard with about a half dozen layers of bubble wrap around the machine.
Manual is simple and terse. It's pretty much the same as his other machines. No empty tank shutoff. Steam valve has to be bled on each power up before you get steam. Not a problem. Power up. Wait for the group to get hot (15-20 minutes). Bleed the steam wand. Good to go in about 90 seconds.
It is short. Nice for filling. Not as nice for cup height. If you want to brew into a cup you have to lose the PF spout. I tried a naked PF. OK, but I tire of the occasional spritz. My personal solution was to cut the nozzle off a Rancilio PF. That gives me (just) enough clearance to get a big latte cup under the PF. About a mm has to be taken off a Rancilio PF's flanges for them to lock in. If you round the flanges too much, the PF can walk out of the head under pressure. DAMHIKT. Do most of it with a belt sander, and then finish with a flat file.
This is a 3" tape measure housing.
The shipped double basket really begs for about an 18gm dose. I get away with 15gm with a Rancilio double basket . So I use the Rancilio. Just a personal preference.
A single 3mm allen bolt holds the cup warmer on. Very convenient to remove if you want to dust the innards etc. The outer case removes in less than a minute with four stainless phillips screws. Very nice. You can use the machine just fine without the covers - as everything functional is attached to an internal frame.
The water tank. It does get up to about 135 degrees F, but that's about it. I don't see any evidence that affects flushing. The flash boil flushes have been no more that 1.5 ounces - if that. I see no functional problem with the heat of the holding tank. Filling the tank is really easy, and the way the fill port is designed it's very easy to fill without overfilling. Much less of an issue than I had expected.
As shipped the cap on the tank makes way too much racket when the pump kicks in. I fashioned a yogurt lid gasket to calm that down. IMO Salvatore should ship such a (10 cent) gasket with the machine.
OK. The coffee. Honest to God, I cannot seem to make a bad cup with this thing. I do a careful weigh/dose/tamp with a SJ grinder, but still. It's weird how good the coffee is. Smooth tiger striped crema that seems to go blond much, much later than with a Silvia. The pump is just a little Ulka. Someone with more knowledge than me will have to explain why it oozes crema the way it does.
Steam. The shipped steam wand head is different than pictured on the Salvatore web. It's basically a cylinder with side holes to accommodate air injection into the stretch phase. It took me at least a dozen pulls to get anything but slurp with it. After getting serious and using the soap drop technique I started getting it. Essentially I don't have to go to the side of the milk, and controlling the stretch is easier with the volume knob than with wand depth. Most of this is I'm sure attributable to the fact that all I knew was a Silvia, and the OneBlack is a little steaming beast. It really cranks.
The valves. What nice things. Smooth as silk. Solid. Functional. And the way the steam and water arms fold up over the tray and then unfold out to the sides is just good design.
Drip tray. Smallish, but you can remove it very easily. Non-issue.
The big honking pstat. It does click a lot, and you can hear it. Someone might object, but I would have to work at it to be annoyed by it.
Maintenance. The manual has clear back-flushing instructions. The process is easy and effective. Not hard to get in the habit of at all. You have to sign a waiver that you will only use soft, filtered water, and mail that back to Salvatore.
What else.... You get a few extras - pictured here.
I'm happy to answer questions as best I can. I owe a lot of good coffee drinking to this web site.
-bruce campbell
