MPatrick wrote:zoomchick,
Apparently the pump had an air lock. I drained the reservoir as Dan had suggested but didn't find anything out of the ordinary. After refilling the tank I operated the pump without a pf in place. The air in the inlet moved quickly through and water flowed as it had prior to the no-flow condition. The problem has not reoccurred.
Bests,
Mickey
I suspect the airlock is inherent in the design. An OPV would have taken care of the problem. Without an OPV there is no way to release the excess pressure created by choking the machine or doing a backflush. The way to avoid it is to be more careful when you backflush and as soon as you hear the pump begin to strain turn it off. Turning off the pump releases the backpressure through the three way valve. My one black does the same thing. BTW checking the brew pressure shows that it ramps up to 15 bars which is what you would expect with a Ulka pump and no OPV.
Ed
