by bowdenoles on Fri Jan 20, 2012 9:18 pm
Thanks for all the replies.
This is a 2008 Salvatore Automatic (E61, HX, Vibe pump, pourover, no filter just the internal reservoir) if I did not mention it. Also the folks at Salvatore have been helpful and responsive. But I am bummed to not have espresso and have the mechanical capability to fix it once pointed in the right direction.......
I sourced a new pump for $50.00 from a local supply house and installed it. Unfortunately, it did not solve the problem. I am not familiar enough with the rest of the components to know where to go next. This is what has been done:
1) Group head was cleaned out to include the screen and brass nozzle. There was only minimal oils and some remnants.
2) The mushroom cap and Gicleur were removed and cleaned in citric acid solution heated to 190 degrees. Again, there was some mineralization but not a lot based on some of the pictures on this site.
3) The 3 way solenoid valve, stem and neculus were removed and cleaned in the solution as well. All of the seals were in good condition and were reassembled.
4) The Ulka pump was removed and replaced with a new one. I tested the old one while it was on the machine and noticed no voltage drop during operation but wanted to eliminate the pump from the list of issues.
So..........Since it builds pressure fine, the hot water valve puts out hot water. The water out of the group head is anemic and when you try to pull a shot it is flat on the naked portafilter, where 2 days ago it did a nice cone and stripping. I have changed nothing with the water, beans, tamp etc. It seems to build pressure to make steam but the pressure is not making it to the brew head.....
Ideas?
