Saeco Vienna Brew Chamber problem
Postby jk3805 on Mon Mar 01, 2010 7:01 pm
Hello
I have a Saeco Vienna that I use at the office. The "brew group" seems stuck. When the machine is turned on, it makes a noise for 2 or 3 seconds and then stops. The brew group cannot be removed and I cannot reset it so that it is in the appopriate part of the cycle to remove it. The indicator on the brew group does not align the arrows and is not in a position to be removed and i cannot get it into that position.
Any ideas? Any help with this would be appreciated.
Thanks
joe
jk3805
Postby espressotech on Sun Mar 21, 2010 4:35 pm
hi
Removing blocked brew group ,you can find how to do it in the following link:
http://www.partsguru.com/user/Brew%20Group%20Removal.pdf
follow the instructions in the document and hopefully you will solve the problem.
best regards
Guy Tzur
espressotech
Return to Espresso Machines
