Running Quickmill Vetrano From a Bottle
Postby sweaner on Thu May 01, 2008 2:42 pm
I currently have a Vetrano sitting in a box, waiting for a kitchen remodel for plumbing.
I can't wait any longer!
I would like to run it off of a bottle, which I have been told it can do without any damage. However, I want to get it right. Do I just put the tube into the top of a bottle? If I use bottled water, will it be soft enough. My tap water is fairly low hardness, close to 3. Can I use this?
Any caveats? Pitfalls?
Scott
LMWDP #248
Man does not live by coffee alone...we need beer too.
sweaner
Postby erics on Thu May 01, 2008 10:04 pm
The Vetrano CANNOT be run from a bottle - you will cavitate the pump.
The suction line connecting the Vetrano's pump (internal to the machine) is 5 x 3 mm and is TOO small for this type of operation. I don't know the exact spec for the proper inlet pressure but I do know that ~35 psi works well. You could hook up a Flojet pump and accumulator and use this to provide proper inlet conditions for the pump.
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby sweaner on Fri May 02, 2008 12:58 pm
Thanks Eric. I seem to have been getting conflicting advice. (not from here) I guess there are some plumbed rotaries that can off of a bottle.
Scott
LMWDP #248
sweaner
Postby shadowfax on Fri May 02, 2008 2:09 pm
Most plumbed in rotary machines have much thicker lines feeding the pump. You could probably run Vetrano from a bottle if you upgraded the internal pump feed line to something a bit wider.
Nicholas Lundgaard
shadowfax
Postby bjorn on Mon Oct 18, 2010 2:57 pm
I have been running my Vetrano from a bottle for a couple of days without noticing any problem. (I'm waiting for getting the plumbing done.) I'm not sure if I'm damaging the pump, though. The seller said that it is ok to run it from a bottle for a couple of weeks.
bjorn
Return to Espresso Machines
