mindless_fool wrote:Chris, where did you get your shur-flo tank from? any Canadian retailers sell accumulator tanks?
I'm using
this 24oz Shur-Flo accumulator tank, which I've seen recommended for home espresso machine use a number of times. The actual water capacity at pressure is more like 2-4oz; the higher the pressure, the less water it holds.
I see EP sells larger accumulator tanks, and also typically pairs the small accumulator with what seems like a more capable pump than the Flo-Jet. In some configurations they provide the accumulator pre-charged to 20 psi like mine is, while in others it is higher.
No matter what the pre-pressurization level, a small accumulator must be emptying for practically every shot, especially when an HX flush is required. This means random pressure drops and spikes from the pump re-filling, which get transferred straight to the machine's inlet.
Presumably some sort of pressure regulator on the inlet of the machine set below the trigger level of the pump would completely smooth out any pressure differences, but I've never seen much discussion of this. I am also unclear on how much I could raise the pressurization of my accumulator before it would make its function redundant by leaving the pump constantly running in use. The max pressure of the Flo-Jet itself is only 40 psi, which is pretty much where I'd like it for pre-infusion. Perhaps I need to look at a higher end pump/accumulator system for this?
