JohnB. wrote:Are you tapping off the RO tank because your water is too hard?
Hi John, I was going to do this because I'd never have to worry about deposit build-up and de-scaling and woudn't have to spend any extra money on water treatment as some do. We have no problems with taste using our RO for tea, coffee and water drinks.
The unit would be going on an island that has both RO water and standard pressure tap water and I just figured that the RO would be "better". As usual, pros and cons. Now I'm back to the mini vs. non-mini again after originally thinking non-mini.
Mini:
- Wouldn't have to drill granite countertop
- Wouldn't have to run 20A line
- Wouldn't have to buy any water treatment/pressure equipment
- Can use existing RO water so won't have to worry about de-scaling and deposits
- Cheaper, especially factoring in first 3 points
Non-Mini:
- Don't need to manually add water
- Pre-infusion makes better espresso
Am I missing anything? I don't think the bigger boiler would be a factor for the 2 of us. Unless the pre-infusion is a huge factor I'm swaying back towards the mini.
