by jlawrence on Thu Jan 27, 2011 1:27 am
Hello all. I purchased a Rancilio Miss Silvia from a U.S. dealer two weeks ago. They shipped it to me in Japan. Unfortunately, the machine does not work when plugged into the wall.
All three lights illuminate and the machine heats up but the pump does not work. Water trickles out of the basket--that's all. I do not hear the characteristic pump whir when I turn it on.
At first, I thought the problem was an incompatibility between Japanese and U.S. electrical systems. So, I tried using a step-up/down 2-way converter, which worked well in Europe, but the only result of that was a blown 15Amp fuse in the converter. Actually, I replaced the fuse twice. The converter is rated 1500W, and the Silvia is only 1100W, according to the electrical schematic.
Then I discovered that Eastern Japan uses 110V/50Hz, while western Japan has the same voltage but a higher frequency--60Hz. (That a country could have different electrical systems is utterly mind-boggling but I digress)
Could anyone offer a suggestion as to why the machine does not work. Is it all because of the frequency difference? Should I take the machine to Western Japan and see if it works there?
What could be a potential solution?
Many Thanks, Jason
