by kjmonopoly7311 on Wed Mar 23, 2011 4:52 pm
Hey there! First time poster on HB! Have spent dozens of hours reading. I'm struggling to find specifics, however, on exactly how to solve my problem.
Bringing this topic back up. So, I just acquired a Bunn ES1A as a bit of a project and have been tinkering with it, although I should admit that my tinkering abilities are novice.
So, upon picking it up and arriving at my parents home, I took the water inlet and hooked it up to a hose which I dropped in the bottom of a 3 gallon water jug, just to see what would happen. It worked! Bravo.
I then left my parents house and traveled home, where I set up the machine again in almost the exact same way. The only difference I can see is that the jug of water is about 10 inches below the level of the 'spro machine in the new setup, while at my parents house it was level with the machine.
The result: No fresh water being pumped/drawn into the boiler. It's not kinks. I tried lifting the jug up to the same level, but still no luck. Still no water being drawn in.
I've read about this before but am having trouble figuring out the next step. Don't want to do anything to the rotary pump.
Thank you!!
