Rotary Pump, Yet Not Plumbed - Page 2
Postby kjmonopoly7311 on Wed Mar 23, 2011 5:02 pm
Well I just went and fiddled with the tube a bit more and saw some bubbles come out, floating to the surface of my jug. Filled with hope, I decided to turn on the machine one more time to see if the auto refill would pull fresh water in, and it did!
Still not sure why/how, so would love comments and any wisdom you have for future use.
Kevin
kjmonopoly7311
Postby HB on Wed Mar 23, 2011 7:39 pm
See Can a rotary pump suck up from a bucket? and Do most plumb-in machines require external pressure? As I noted earlier in this thread, you need a check valve:
Ball-type check valve assures water flows only one direction
Previous
Return to Espresso Machines
