darrensandford wrote:I engaged the pump, but I couldn't hear it over the extractor.
40 minutes later and it was still running, but sounded rough. Touched the motor - hot. Touched the pump - OW! Very hot! Removed the PF and ran some cold water through for a few seconds to cool the pump.
Tried it again later and it sounded fine, no strange noises or funny smells.
Still working perfectly several months later. There may be latent damage to the pump, but I can't tell.
[a doubt about your comment comes to me.. do you mean "I engaged the pump
without water"??]
Same thing happened to me, same thoughts comes to me... no strange smells, sound rough (and metallic, and like it tried to, I'd add), and hot, ... I suppose to so like yours one... I can touch with hand easily... maybe was at 40 °C (but the aluminium casing, impossible to know nothing about the interior.), and bad feelings about the future of the machine because of this
So you mean 40 minutes with no water and now still perfectly works like first day without any bar noise / sign? (If I understand well), that proves the durability of this motors... although, as Dan says, "is definitely not recommended" use them like that.
cannonfodder wrote:I would be more worried about an empty boiler and energised heater for 4 minutes. That has a bad tendency to blow out heating elements. If you hook everything back up and it works without issue, count yourself lucky and make some coffee. The good thing about these parts (or bad thing) is that there is very little to go wrong. It will work, or it will not.
Well.. I have test the machine and, apparently works normal.. I consider myself lucky... Ufff
Anyway.. I though on this before... and there is not reason to be worry, because while the boiler is refilling, the heating element is off... Thankfully, I was lucky on one thing...and the decision of the engineers to switch off the heating elements while the boiler is refilling, help me to not ending of broken the machine...
Thankfully.....
