by dmankin on Wed Apr 30, 2008 10:07 am
Thanks, Eric. I plan to send the pump to J C Beverage in Minnesota for a complete rebuild. They charge $43.50, which seems more than reasonable to me. The rebuilding of the pump will fix my leaking pump problem, but there is still the issue of sound to address.
Check out this video of my motor running without the pump attached - by no means silent, or even close! Is this abnormal? Acceptable? Can one lubricate a noisy motor? I can rest just fine with the machine's noise level, but I really want to figure if this machine is meant to be this loud, or did it come from the factory nearly silent and has worked its way to this point.
Thanks for all your input.
David
