Abe Carmeli wrote:The preinfusion chamber works well with a vibe pump, but once you convert to rotary, it will go to max pressure in about 2 secs. A little too fast for real preinfusion.
The preinfusion for the Microcasa is all manual; I wait ten seconds during which the brew pressure is 1.2 bar. The E61 vibration pump machines I've tested reach max pressure in six seconds, maybe a little less. The three rotary (non E61) machines I've looked at closely (La Spaziale S1, Cimbali Junior and Elektra A3) rocket up the pressure in a few seconds; droplets are forming in four. The Lineas I've tried behaved similarly, i.e., the pour starts long before it would for an E61 / vibration pump.
And yet the extractions from the A3 are
sooooo-o-o much easier than other rotary pump machines I've tried, and the only thing I can point to is the effects of preinfusion. Hey, that's only three seconds... how'd it happen so quickly and effectively? This observation is forcing me to rethink the importance of the length of the "preinfusion pause", a thought which leads me to a concrete question:
What's the programmed prefusion delay for the Synesso Cyncra?
Background: I briefly used the Synesso Cyncra in the BGA booth at the SCAA conference in Seattle. As I understood it, you had the choice of a manually selected preinfusion delay by pushing the pump switch halfway across, or a programmed preinfusion delay by pushing it straight across. It seemed like the pour commencement times were consistent with other commercial machines, but like I said, I only used it briefly... Chris or other Synesso fan, would you fill in the details?
