DickC wrote:I'm converting to a rotary pump for my Expobar. I've read a bunch of past posts and done some research, but I still have a few questions.
The pump will be under the counter, fed with filtered water at house pressure of about 45 psi. Pump is a ProCon model 112A060F11CB130 (a rebuilt one, from some nice people at JC Beverage Co. in Minnesota for $58.50). Motor is 1/4 HP small one from EPNW, on the expensive side, but fitting my space.
I spoke to an engineer at ProCon, and here are a few factoids (according to him) I hadn't found definitively elsewhere:
(1) the 060 in the model number is a gallon-per-hour specification and is way more than needed, however as long as it's enough it doesn't matter, the pump won't waste anything, heat up, or wear more because of excess capacity.
(2) pressure is adjustable, within range, and is insensitive to input pressure, as long as flow is sufficient.
(3) the CB in the spec is what ProCon recommends for espresso, although JC Beverage is used to supplying DB. CB is also what EPNW sells in their new pumps (however theirs have 3/8 BSP ports instead of 3/8 NPT as mine has).
(4) Yes, the input pressure will appear at the output when the pump is not running. Presumably could be used for boiler fill and pre-infusion.
Not tested yet, but I think all that is correct.
Dick, here's a link at Procon that explains all those characters in the part number,
Procon Standard Series Model Number Matrix.
Can you adjust the pressure or is it preset on that particular pump you have there? Can you post a picture? I am just curious.
FWIW, I just pulled a rotary pump (different manufacturer) rated at
600 LITERS per hour (~160gph), so I guess that can vary a good bit! This one also has the balanced bypass like yours.
Questions:
(1) Solenoid -- Do I need (should I include) a solenoid valve. I have a manual shutoff for maintenance, etc. Maybe a solenoid is a good idea, in case my tinkering leaves a flakey joint some time. OK to have it on with machine power? Or if just with the pump? Should it be before or after the pump?
Well, you'll need a relay to turn on the pump, might be a good idea to open a solenoid as well at the same time if one does not already exist in your brew circuit. A normally closed valve may help you sleep better. That said, it should not be needed. But, if you want to mess with mains pressure preinfusion, leave it out (but add the regulator). See
Is there a purpose for the E61 middle brew lever position? for details.
(2) Regulator -- Do I need one? Some comments have suggested that brew pressure can be adjusted by varying a regulator on the input side of the pump (contradicted by the ProCon engineer). I'll be easily able to access the adjustment on the pump.
I don't have enough experience with these pumps to know for certain, but as indicated to you by Procon, the balanced bypass is supposed to be independent of inlet pressure. I'd still add a regulator for peace of mind.
(3) OPV -- I'm planning to install the Expobar's OPV, under the counter, in line fed from the output of the Procon, as a safety with the pressure set up above the brew range.
Most rotary pump machines have an OPV that is not used to regulate brew pressure (the pump is adjustable to set the pressure), but is set much higher (like 12 bar or so) for safety/expansion reasons. These typically dump to the drip tray. Where will you send the OPV outlet? Would it be easier to leave it in the machine and crank the setting up?
(4) check valve -- Someone recommended having one, in the machine I think, to prevent draining water if the machine is disconnected. Is there any other reason?
Plumbing code may require it. Cheap peace of mind, John Guest makes one for about $12 that you can add to the supply line.
(5) I plan to use John Guest 1/4" tubing from pump to machine, except for a short braided hose above the counter. Any reason to use anything else? How about JG quick-connects? Are they OK for brew pressures?
No problem. JG fittings aren't cheap but they are easy and flexible.
(6) Is there any problem or consequence to having the Hx pressurized during idle times? I just installed a brew pressure gauge, and I find that if I don't release it, the brew pressure stays in the thermosyphon circuit for quite some time. Presumably, the house line pressure would be there all the time if no solenoid is fitted, or if it stays on when the machine is powered up. I don't understand boiler dynamics enough to have a sense if this would affect thermosyphon action or whatever.
Line pressure would be there with no solenoid in the brew circuit. You can relieve the brew pressure by lifting the lever halfway if you had a solenoid.
Since you are plumbing it in, have you considered any water filtering/softening/regulator packages?
