clinto wrote:yeh not sure about the pump, but i think they all seem to be much the same externally.
I also have a 3 group La Cimbali M31 from the 80s and a 2 group La Cimbali volumetric from the early 90s. bought the 3 group at auction for $200 (on impulse after I had bought a Rancilio MD50 grinder) and the 2 group from ebay for $300. 3 group has been stripped to the frame for a rebuild 2 group is running but is pumping out milky water so will do a descale when i get the 3 group running. plan was to use 2 group as a bit of a test bench or part it, but now will probably aim to get them both working and get rid of the 3 group as it is probably a bit big for home use.
but point of my post is that the pump on the 2 group had seized so I swapped it with the 3 group one. one pump was procon the other was a no name brand. but both appeared to be pretty much identical externally. only really some fins on the external case and the attachment of front part of the pump that were different. the motors were different though so not sure if that results in different flow rates for the two pumps.
DickC wrote:I can imagine that sensitivity (of pressure) to input pressure, output demand, pressure smoothness, etc. might all be possible and also depend on many other things as well. It's hard to think it would matter a lot, or even a little, (to the coffee) for a one-group machine.
erics wrote:For pumps that have a standard relief/regulating valve, the output pressure varies with the inlet pressure to the pump. For all practical purposes, it is a proportional relationship (1:1).
For pumps that have a balanced relief/regulating valve (like yours), the output pressure is essentially constant with varying input pressure within a reasonable range of input pressures (this is my opinion, not necessarily fact). By reasonable range of input pressures, I mean anywhere from, say, 20 psig to 60 psig. I have certainly not seen any test results from pump mfgs to verify this but if they say it will perform in this manner - ya gotta put a little faith in that.
The business of actually delivering a minuscule portion of the pumps output to the grouphead while still maintaining smooth output pressure is another story. Using an old(?) controls systems term, I believe that is approaching the turndown ratio limits of the relief/regulating valve. I do know that there have been posts to the coffee forums wherein "larger" pumps have been applied to one-group machines and I assume it was successful as I hope you will be. Another quick source, right in your neck of the woods is Chris Coffee who sells a ton of Vetranos. It would be a good piece of info to know exactly what Procon or Fluid-o-Tech pump is installed in Vetrano.
erics wrote:It would be a good piece of info to know exactly what Procon or Fluid-o-Tech pump is installed in Vetrano.
RegulatorJohnson wrote:
mteahan wrote:In a balanced system, the pressure of the inlet water places additional pressure on the spring loaded piston on the inlet side of the pump. As the pressure increases or decreases it balances against the spring tension to keep the pressure constant. An unbalanced bypass places pressure against the pistons pressure on the seat of the bypass. Increases in pressure result in higher than desired pressures on the output side of the pump.
mteahan wrote:DO NOT use the expansion valve to adjust pressure.
mteahan wrote:If you want to run plastic, get Teflon line from someone like Pisco Products and find some kind of sleeve to put around it. It slices very easily.
jesawdy wrote:(Dick, my apologies to turning your thread into a repository of rotary pump models and specs.)
