decaf_Ed wrote:Is this the same pump that's providing the pressure to pull shots?
That's correct, the pump serves both purposes. A solenoid controls filling the boiler. I searched this site using "hydraulics diagram" and found this example:
Pump = part #2, refill solenoid = part #3; excerpted from Nuova Simonelli Oscar product pageIdeally, the controller would be programmed to delay refilling the boiler for 20-30 seconds if brewing was in progress, but that hasn't been my experience. You're right that for a vibratory pump, the brew pressure drops if an auto-fill kicks in mid-shot. If you prewarm the cups as Ian suggests, it will never happen. If you forget, it may happen... oh I don't know... once in 20 or 30 shots, depending on how often you steam.
