Rocket Cellini Evoluzione - does it shift when locking in portafilter?
- Rico
Hello,
I Have a Rocket Cellini Evo V2 on its way and I wanted to plumb it in. My question is will the lack of water weight in the tank be an issue when I crank the PF in? I could tell when my Silvia was getting low because it would move the machine when I loaded it. I have never seen a Cellini in real life, so it may be heavy enough with an empty tank.
Thanks, Richard
Thanks, Richard
- HB
- Admin
The E61 type espresso machines I've used don't shift around unless you really gorilla tighten it. My Rancilio Silvia portafilter required a lot of torque to seal; I needed to break that habit when I upgraded. FWIW, the Cellini weighs 46 pounds (dry) versus 30 pounds for Silvia.
I had a felt pad under each leg for easier movement to access the tank (not plumbed and under a counter). Even still there was no movement when locking the pf.
- jgirl125
I've never understood why some people "gorilla" the PF into the brew group. I've always been able to use a moderate amount of force, just enough to get a good seal without torquing the machine to the point where it would move. Keeping a fresh brew head gasket that pliable will help to make the seal work with less force. I always have a spare one on hand as they are pretty inexpensive.
My Giotto weighs about 21kg and it generally isn't moving unless you try really hard.
