JmanEspresso wrote:Just addin my .02..
I am of the mind, that the problem lies not with your tamper at all, rather your dose. Simply try adding more then 14gs of beans, and your problem, with almost 100% certainty, will be solved.
I fell into the same kind of problem when ordering a silvia and 58mm tamper from 1rst line. I'm sure you're very knowledgeable about espresso but I have to disagree with this statement (only applying to the silvia stock double basket and 58mm tamper of course) because I've had the same binding experience as the OP.
Trying to updose on the silvia stock double basket, your puck hits the big freaking dispersion screen bolt head and does not make for good results. I think I also read that the silvia is very temperamental to updoses somewhere in the Silvia favorites thread.
Buying a ridgeless double basket is the way to go I think. Much cheaper than buying a new tamper.
