(Note, this problem was solved with the help of member
erics (see the last posts in the thread). Yet another fine example of folks in this forum sharing knowledge and helping each other out -- Thanks!)
I am restoring a 1979 Elektra single group HX commercial machine (see the
detailed post in the restoration section of the coffeegeeks forum for the details of my adventure with this project).
I have a problem I would like to address to the larger audience in this forum that has to do with a problem I'm having with restricted water flow to the grouphead when the brew circuit is engaged.
Here's what I know so far:
1. The pump seems to be working fine because it fills the boiler quickly even when it is under pressure (about 1 bar).
2. The plumbing from the HX to the grouphead seems to be flowing just fine because the grouphead heats up quickly when the boiler is heating up and stays hot -- so the convection heating plumbing (which also supplies pressurized water when the brew circuit is engaged) must be flowing freely.
3. Given the above 2 facts, the 4 areas that I can think of that might be involved in restricted flow are:
a. The solenoid that engages when the brew circuit is engaged that diverts water from the pump from the boiler to the HE.
b. The check-valve that is in the line from the solenoid mentioned in "a." to the HE might be clogged-up.
c. The pressure-relief valve for the HX might be leaking (although I don't seem to see much water flowing from the drain line when the brew circuit is engaged, so I doubt this is the culprit
d. There may be a clog or a partial blockage of the 3way valve in the grouphead causing the restriction
My question to you repair and maintenance gurus out there is which is most likely to be the culprit? Have I missed any possibilities?
The flow of water from the procon pump to the grouphead when the brew circuit is engaged is as follows:
1. The selector solenoid that determines where the water from the pump goes to is engaged to send the water to the heat exchanger (HX).
2. The water then flows through a check-valve
3. The water then goes into the bottom of the HX, where there is also a line going to a pressure-relief valve that is connected to the drain line.
4. The water line from the top of the HE goes to top port on the grouphead.
5. The water line from the bottom of the HE goes to the bottom port on the grouphead.
6. When the brew circuit is engaged, the 3way solenoid valve in the grouphead is activated and allows the water to flow to the filterscreen in the grouphead instead of recirculating through the channels in the grouphead.
7. When the brew circuit is turned off, the 3way solenoid valve in the grouphead closes off the flow the from the HX to the filterscreen in the grouphead and opens up the convection water flow through the grouphead from the HX.
That's the water circuit in this machine as I understand it.
I look forward to your replies and assistance.
Thanks,
Philip
PS added by moderator: Same question
cross-posted on Coffeegeek.
PPS added by poster -- I got no response on Coffeegeek, so I posted the question here.
