Restoring my new Pasquini - Page 5
Postby Ross Leidy on Mon Dec 15, 2008 10:53 pm
Time for a bit of a progress report. The machine did not come with the drip well that mounts under the main drip tray. I found the part online at a number of sites, but I could not bring myself to shell out $45 for a hunk of plastic. After a bit of searching around at Home Depot and Lowes, I assembled a simple collection of parts to build my own for $7. I used an end cap for 4" abs pipe, a right-angle barbed abs fitting, and a pvc adapter (alas, it did not come in abs, but it won't show under the machine). I already had the brass toilet tank bolt and washer. I had to trim the height of the cap to make it fit, but overall it was a simple project. Works like a charm.
Ross Leidy
Ross Leidy
Postby Ross Leidy on Wed Dec 17, 2008 11:39 pm
Preview
Since I do woodworking as a hobby, I decided to incorporate some wood into my project. The metal control panel was in rough shape, and it seemed like a good place to make a substitution. I think it's going to look sharp.
Ross Leidy
Ross Leidy
Postby shadowfax on Thu Dec 18, 2008 12:10 am
Ross,
This reminds me why I love amateur restorations so much. :)
Thanks for letting us join you on your wonderful journey.
Nicholas Lundgaard
shadowfax
Postby Ross Leidy on Thu Dec 18, 2008 10:18 am
I hope that by amateur you mean "first time restorer" and not "Oh, no, he's using duct tape and bailing wire. This is going to be fun to watch." :)
Ross
Ross Leidy
Ross Leidy
Postby shadowfax on Thu Dec 18, 2008 10:21 am
Ha, absolutely not the latter. Your work looks pretty professional to me. The wood panel looks quite nice.
Nicholas Lundgaard
shadowfax
Postby mhoy on Thu Dec 18, 2008 11:25 am
I also think you are doing a fine job! Perhaps some beautiful wooden portafilter handles to match. :wink:
Mark
mhoy
Postby Ross Leidy on Thu Dec 18, 2008 1:26 pm
Thanks, guys. The portafilter handles would be fun. I don't currently own a lathe, but recently I've been keeping my eyes peeled for craigslist deal for that very reason. :D
Ross Leidy
Ross Leidy
Postby Ross Leidy on Thu Dec 18, 2008 11:19 pm
I haven't got to polishing the stainless, but I wanted to get the machine assembled to use during Christmas. The stainless bits are easy to remove, for the most part. The upper section with the steam wand handles requires a bit of extra work to remove, but shouldn't take too much effort.
Here's a shot with the wood panel in place. A couple more coats of poly and I'll be able to drop in the controls and indicator lamps.
Above the panel is my new bottomless portafilter from Great Infusions. It seems to fit correctly, but a little looser than the original. I may need to add a shim below the group gasket to help it lock-in a little tighter. I've only tried it once (prior to assembling all the exterior panels) and I got a generous spray everywhere, including around the gasket. Hopefully, my next attempt will be a little less explosive.
I had to replace the dual gauge because the boiler pressure half was damaged. Since installing the new gauge, I've reduced the pstat so the gauge reads about 1.2 bar at the top of the cycle. My initial attempt to check the group temp with the cup of water and candy thermometer reads pretty low (about 185), so either the thermometer is off, or the gauge is off, or the shot glass lost the heat very quickly. I need to buy a instant-read digital thermometer and check it again. I do get a few seconds of sputtering on the initial flush, so I know it's hotter than 185. Lots of tuning ahead.
Ross
Ross Leidy
Ross Leidy
Postby cannonfodder on Fri Dec 19, 2008 7:50 am
While you are at it, ditch the stock knobs and portafilter handles and make yourself a matching set. If you are using polyurethane make sure to get the back of your panel. There is a lot of heat and moisture around that panel, you may get some warp or bow if it is not sealed up. I use WaterLox gloss Marine finish on wood that will see damp conditions.
cannonfodder
Postby Ross Leidy on Fri Dec 19, 2008 9:57 am
Dave,
That's some nice work. Cocobolo? Now I have to get a lathe. :)
Yeah, I plan to apply at least as many coats on the back side as the front. I used a piece of lauan on the back as a substrate for the plank of bocote that is visible. The lauan will soak-up the poly, so I hope that will be enough to protect it. I also thought about attaching a thin piece of rigid sheet insulation to the back side for extra protection.
Ross
Ross Leidy
Ross Leidy
PreviousNext
Return to Espresso Machines
