The lady didn't have it plumed in so I got a signed, dated receipt to say that it was in full working order so that if it isn't I could take it back (which I don't really want to do).
Here is a quick front and sides. One of the lights (red in colour) isn't present on the front pic but it is there, just the thread has cracked on the plastic and the metal disc has been lost so it won't stay in place.
It was a little older than I thought, 2000 I believe, the electrics are marked as dec 2000 and May 2001. Under the cover for the electronics seem to be in very good order. Below are the wires coming off the main power switch.
As you can see from the next pic the electronics under the cover are fine, but those not are a little grungy, and the floor needs a good old clean. (The purple ring will come into play shortly)
This (below) is at the front right of the machine next to the electronics, I don't really know what it is (pressure over flow?), but it was really just to show that I put a little de-scaler on it for a couple of seconds and it came off pretty easily.
I switched it on to make sure that it would turn on. It did and it sounded as though the pump was running which was a good thing. Checking that there was some water in the tank (with a wooden skewer via the boiler level probe nut which I removed) I quickly pressed one of the dispense buttons on for the left group, but nothing came out. I switched the machine off/on and tried it with the right. This resulted in a very loud 'warning buzzer' sounding. Anticipating something like this may happen I had my finger on my circuit breaker and off it went after half a second. I also noticed water coming from the brew/auto fill solenoid (see below) which is not attached correctly, broken or simply unscrewed I do not know as I thought it better to seek advice before messing about with it.
The last thing to say is that looking inside the tank there is a lot of scale and does need a fully, well, de-scaling. I intend to do this by stripping it down but a couple of questions.
1) I do intend to fully strip it down and de-scale it, but before I get that far, I haven't seen any water come out of the group yet. Should I plumb it in and see if the tank fills and I can get water to come out of the GH's? This will of course mean fixing the solenoid leak first. Also there is always the possibility of thick scale blocking the pipes. I only assume at the moment I can plumb it in because there is an outdoor tap plumbed in under the sink, a converter may be needed.
2) Before buying I asked about power supply. A user suggested that a normal mains plug would be okay. And I know it did switch on through a regular 13A fused plug but my maths says I=P/V, I=3700/230 =16A. Can you get a standard UK plug with a 16A fuse? Even if you get a converter from the 16A plug to a 'normal' plug, that will still have a 13A fuse.
3) I think I'll go with the citric acid method of descaling. I.e. chuck all the pieces in a bucket and let it get on with it. here this seems to be a good place to get it. It's labelled as "100 % Fine Anhydrous Grade Citric Acid" £10 for 1kg delivered to my door. Is this the right stuff? How much will I need? What proportion of acid to water?
4) Going back to the purple ring in the electronics picture, there are 2 sets of electronics, one for each group. The one on the left has these wires (circled) but the one on the right does not. Is this important?
5) I'm going to need several parts including a drip tray, electronic programming key and probably gaskets to start. Any recommendations for suppliers?
Thanks in advance!
Damien
(The names of the parts were supplied by Dave in this topic http://www.home-barista.com/espre...ow-mine-t6800.html started by Mark Hoy)
