Restoration of used Elektra Sixties T3 - Need some advice please - Page 3
Postby erics on Fri May 29, 2009 9:13 pm
Get a small can of penetrating oil and put a few drops on the exposed threading at both A and B. Let this sit for an hour or so.
1. Pretend you are on the "A" side of the valve body looking at "B" for all operations.
2. Get a wrench to fit the hex of the fitting at "A". Get a somewhat larger wrench to fit the tubing nut to the left of "A".
3. Turn the larger tubing nut counter-clockwise while applying an equal clockwise force with the smaller wrench on the fitting at "A".
4. Now apply a wrench to the hex at "B" and an even larger wrench to the valve body. Turn the entire valve body counter-clockwise while applying an equal clockwise force with a smaller wrench on the fitting at "B".
Skål,
Eric S.
http://users.rcn.com/erics/
erics
Postby DDTTAA on Sat May 30, 2009 4:47 am
i think the small selection of spanners i have isn't up to the job so it's a good excuse to purchase some! are the nuts on the machine metric or imperial (AF)?
EDIT - having had a quick mess about with a vernier caliper they appear to be metric - could someone please confirm this?
Also discovered my 17mm spanner ranges in size between 18.5-21 mm.
DDTTAA
Postby mhoy on Sat May 30, 2009 11:17 am
DDTTAA wrote:EDIT - having had a quick mess about with a vernier caliper they appear to be metric - could someone please confirm this?
I think it's mixed... (or some of the imperial perfectly fit some of the metric nuts). I have a set of Imperial wrenches and ended up using Imperial and an adjustable wrench. Didn't round off the nuts so I'm happy. :D
Mark
mhoy
Postby DDTTAA on Sat May 30, 2009 3:42 pm
well i have an adjustable spanner and just ordered a 25 piece metric set which goes from 6-28 in mm (+ a 30 and 32) so should be too far off. one hopes.
DDTTAA
Postby cannonfodder on Sun May 31, 2009 6:50 pm
They actually make wrenches for tube fittings. I would suggest getting a set. Unlike open end wrenches, these have a smaller open end and a larger head to fit around the fitting. That way you get relatively even pressure all the way around the fitting and have less of a chance of torquing/bending the pipe fitting. They resemble a closed end wrench with a small cutout for the pipe to go through. Brass is soft so be careful or you may bend/buckle the pipe and/or fitting. Just about everything is metric so I would start with a metric.
cannonfodder
Postby DDTTAA on Sun May 31, 2009 7:12 pm
hi, they took me a while to find but is this the type of wrench you are talking about?
http://www.tooled-up.com/Product.asp?PID=13151
DDTTAA
Postby Ben Z. on Sun May 31, 2009 7:18 pm
That's right. Commonly used on automotive tubing fittings.
Ben Z.
Postby cannonfodder on Sun May 31, 2009 10:45 pm
Yes. I have a set in metric and imperial but I was using them on fuel and break lines long before espresso machines. You can get them at about any tool supply shop, all the major manufacturers make them.
cannonfodder
Postby DDTTAA on Fri Jun 05, 2009 12:18 pm
I finally got my tools and managed to get the valve body off in seconds with no problems. Just shows what the right set of tools can do! Anyway I'm still waiting for the replacement parts (2 weeks now) but once it gets here I will be able to test it out then get on the go with the strip down.
I have a few questions about which parts I should be replacing - more may come up as I find and problems when it is up and running but I'm just looking for suggestions for things I should definitely be doing now.
Gaskets - the machine is around 8-9 years old and I am completely unaware of the service history. Should I be replacing the complete gasket set in both the groups?
Shower screen - to replace or not to replace? I have not taken the machine to pieces yet as I am waiting for these parts (mentioned above) to arrive to test out a few things first so I cannot comment on the condition of the group head parts.
Grease for fittings - when I took off the solenoid body I noticed it had grease on the threads. I assume this would be a good idea when putting back together. What type of grease should I be using? Where would I be able to get suitable grease (UK)? Does this grease go on all the fittings?
Power - I'm not comfortable running this 16A machine off a 13A supply. I'm trying to find out whether my sockets are 30A or 15A - neither building super nor fuse box is any help. Is it possible to reduce the power so that it runs below the 3.7 kW to say 2.9 to make it run safely off a standard UK plug (13A)? Will this require any special tools/equipment?
Frame - it's pretty grimy in there and I'm thinking I will strip it down and repaint it? I have these for stripping paint Here would these be a bit harsh? What is the recommended method? Is it a special type of paint (for re-painting purposes) - heat resistant perhaps?
Outer case - it's a little grubby and on one side a pouch had been glued on for holding a document of some kind, but I guess with the heat the glue has become pretty attached to the case. Do I just scrub and scrub until it comes off? Is it solid stainless steel? Are there any special cleaning products for the case?
PF's - the pf's have black plastic handles, which according to the schematics should just twist off the pf body but with all my might I cannot shift them. I would like to replace them with the wooden handled version. Do these handles just screw off or is it a case of buying the entire pf? I know you can order the handles on their own.
Cosmetic - firstly the Elektra logo on the front has been worn down by cleaning. Can you get the stencil and paint required to re-do this? The information/ SN plate has also been worn down by cleaning. I would like to replace this, but I don't know if that would be possible for the reasons that it may be illegal and its 'riveted' on rather than screwed on. Any thoughts?
Lights - I do need to replace one, is it best to replace them all, as they don't really cost any great amount?
Thanks for the help.
Damien
DDTTAA
Postby mhoy on Fri Jun 05, 2009 10:53 pm
DDTTAA wrote:I finally got my tools and managed to get the valve body off in seconds with no problems. Just shows what the right set of tools can do! Anyway I'm still waiting for the replacement parts (2 weeks now) but once it gets here I will be able to test it out then get on the go with the strip down.
I have a few questions about which parts I should be replacing - more may come up as I find and problems when it is up and running but I'm just looking for suggestions for things I should defiantly be doing now.
Sound like a fine plan. Here is what I remember from a year ago when I rebuilt my T1.
DDTTAA wrote:Gaskets - the machine is around 8-9 years old and I am completely unaware of the service history. Should I be replacing the complete gasket set in both the groups?
If it came into contact with heated water, I'd change the gasket. I think I changed every gasket in the whole machine as I figured I might as well not have to do this again for a long, long time.
DDTTAA wrote:Shower screen - to replace or not to replace? I have not taken the machine to pieces yet as I am waiting for these parts (mentioned above) to arrive to test out a few things first so I cannot comment on the condition of the group head parts.
No need to really replace it if you can get it clean. I used a needle and spent a while poking holes and dunking it in boiler water + Cafiza.
DDTTAA wrote:Grease for fittings - when I took off the solenoid body I noticed it had grease on the threads. I assume this would be a good idea when putting back together. What type of grease should I be using? Where would I be able to get suitable grease (UK)? Does this grease go on all the fittings?
I used Teflon tape on the copper/brass threads for the water lines. I used Dow 111 on internal stuff.
DDTTAA wrote:Power - I'm not comfortable running this 16A machine off a 13A supply. I'm trying to find out whether my sockets are 30A or 15A - neither building super nor fuse box is any help. Is it possible to reduce the power so that it runs below the 3.7 kW to say 2.9 to make it run safely off a standard UK plug (13A)? Will this require any special tools/equipment?
You can easily disconnect one of the three heating elements and reduce the power by 1/3. Under the cap that protects the elements from water you'll find 6 metal studs with brass/copper connectors between each leg. Remove one set and voila 2/3 power.
DDTTAA wrote:Frame - it's pretty grimy in there and I'm thinking I will strip it down and repaint it? I have these for stripping paint Here would these be a bit harsh? What is the recommended method? Is it a special type of paint (for re-painting purposes) - heat resistant perhaps?
It doesn't really get all that hot on the frame, perhaps where the steam and water are connected but for the most part any spray paint would probably work just fine. I didn't strip it, I just de-greased it and sanded off the rusty areas and hit it with some spray paint as most of the frame was in great shape.
DDTTAA wrote:Outer case - it's a little grubby and on one side a pouch had been glued on for holding a document of some kind, but I guess with the heat the glue has become pretty attached to the case. Do I just scrub and scrub until it comes off? Is it solid stainless steel? Are there any special cleaning products for the case?
The good news is that the stainless is likely in fine shape under the glue. Getting it off, try one of the Goof Off or similar products. It's solid and heavy duty Stainless steel. I ended up buying a cheap 6" bench grinder, some pads and went to work on it. It took forever but had a mirror like shine when I was done.
DDTTAA wrote:PF's - the pf's have black plastic handles, which according to the schematics should just twist off the pf body but with all my might I cannot shift them. I would like to replace them with the wooden handled version. Do these handles just screw off or is it a case of buying the entire pf? I know you can order the handles on their own.
You can just buy the portafilters, I got a couple of less than new ones from Stefano's to mess around with. They don't have the Elektra logo, but they were cheap enough for me to mess with. He thew in a couple of cheap rubber handles so I could easily hold onto them.
DDTTAA wrote:Cosmetic - firstly the Elektra logo on the front has been worn down by cleaning. Can you get the stencil and paint required to re-do this? The information/ SN plate has also been worn down by cleaning. I would like to replace this, but I don't know if that would be possible for the reasons that it may be illegal and its 'riveted' on rather than screwed on. Any thoughts?
I inquired and no, you can't get them. If you figure out how to do this I would also be interested. I my S/N plate was also almost unreadable and I choose to relocate it and polish up the stainless to match in that area.
DDTTAA wrote:Lights - I do need to replace one, is it best to replace them all, as they don't really cost any great amount?
If they are brittle replace them, if not leave them alone.
Mark
mhoy
www.baratza.com: skilled in the art of grinding
PreviousNext
Return to Espresso Machines
