Resetting a Fuji PXR3 to factory settings
Postby 703Eric on Mon Jun 16, 2008 5:18 pm
Hi, Does anyone know how to reset a Fuji PXR3 to factory settings? I just installed a PID unit on a linea and I think I messed the programming up.
Thank you,
Eric
What luck for rulers that men do not think. A Hitler
703Eric
Postby cafeIKE on Mon Jun 16, 2008 6:08 pm
PXR3 Manual Link
You may want to try an AutoTune as a place to start. Start the AutoTune @ ~ 180 to 200°F
cafeIKE
Postby 703Eric on Mon Jun 16, 2008 6:15 pm
have set all the parameters and double checked them but the brew boiler will not stop heating. it hits the CV value and just keeps going up.
703Eric
Postby 703Eric on Mon Jun 16, 2008 6:20 pm
I just tried to do Auto Tune but if just keeps heating past my High value. I would like to reset the PID to the factory setting and start again.
703Eric
Postby cafeIKE on Mon Jun 16, 2008 6:49 pm
Have you've verified the SSR is ok by disconnecting the DC control from the PID?
cafeIKE
Postby 703Eric on Mon Jun 16, 2008 6:53 pm
Thanks for your help Ike, How can i check the SSR by disconnecting the Power to the PID? Sorry, I am a bit of an electronics idiot.
703Eric
Postby cafeIKE on Mon Jun 16, 2008 7:00 pm
Oh...
The output of the PID is normally a DC voltage that is fed to the DC side of the SSR.
http://www.ielogical.com/coffee/SSRMount.JPG
The RED wire, connected to +, is the one you need to lift.
If you remove the control input from the SSR, the machine should stay cool. If the SSR is blown closed, an unusual failure, the machine will heat regardless.
Is it possible that you have the SSR control wired to the wrong terminal and it's always on?
cafeIKE
Postby 703Eric on Mon Jun 16, 2008 7:05 pm
Just disconnected the red wire from A1+ on the SSR to position 5 on the Controller and the boiler keeps heating
Eric
703Eric
Postby cafeIKE on Mon Jun 16, 2008 7:10 pm
Ok. Leave that disconnected.
Remove AND INSULATE / ISOLATE one of the A/C leads to the SSR.
What model SSR are you using?
BTW, DEBUG :?: UNPLUG :!:
cafeIKE
Postby 703Eric on Mon Jun 16, 2008 7:13 pm
Its a Carlo Gavazzi from Espresso Parts
703Eric
Next
Return to Espresso Machines
