Reservoir setup for ECM Giotto Classic
Hello all,
I've just bought a barely used ECM Giotto Classic and discovered that it lacks a water reservoir. All it has now is a long tube on the pump inlet. I presume the previous owner 'fed' the pump from an external bottler/filter.
Does anyone have any (actual, or links to) pictures of the reservoir setup that I need please?
I'm not sure it actually intended to have a reservoir because there's no pop-out panel under the cup holder for internal access; everything is bolted down. Maybe these were never reservoir fed. I found a source for a Rocket reservoir, but maybe that's not the way to go.
Can anyone advise me?
Nathan (an E61 newbie)
- homeburrero
Does your reservoir compartment look like this?
If so, you want the old style rocket/ecm giotto classic tank. For example,
http://www.1st-line.com/store/pc/Rocket ... 1p3505.htm , which Is currently listed as out of stock - but you might call to see if they can still get one. With that one, be sure you also get the two supports/probes and the plug.
It should have two plastic hoses into the reservoir - one for the pump inlet, and another that connects to a tee that has a line to the pump priming valve and a line to the OPV valve. More pics of what the reservoir looks like can be found in this thread: Diagnosing Dead ECM Giotto
The one with a round well and o-ring fitting at the bottom is for the newer Rocket premium Giottos. If it's for a Rocket Giotto classic, it should work in the ECM Giotto classic - check with the vendor to make sure.natmat wrote:I found a source for a Rocket reservoir, but maybe that's not the way to go.
Pat
Hi, thanks for quick reply.
The innards of my Giotto look like your linked article, where there is space for a tank. However, the panel on the top of my Giotto doesn't have a cut-out for a tank, so even if it had a tank it it would not be removable (without removing 4 screws each time and removing the entire top metal panel) nor easy to fill in place with the current setup. So I would need to have some metalwork cutting done to provide an access hole to put it in/out.
Also the is only one water pipe, the pump inlet. The OPV outlet plumbs to the front panel, I don't think there's a pump primer tube (though will check). I'll take a photo and post it.
But it looks like I'll be feeding it from an external bottle/source of water.
