Hi Cindy,
I can't help you with the pump replacement - mine is over a year old and I've had no issues with it (knock on wood). However, I moved from Newfoundland, Canada to Fort Worth, TX, so I had to drain my machine. Here's the instructions I received from Zcafe (the distributor in Canada) for draining the machine. I followed these steps with no issues, and the machine arrived safe, sound and dry. Remember that after you drain it, you have to prime the machine like you did the first time.
I've pasted the instructions sent to me verbatim. I can't take responsibility for grammar errors.
Draining the Boiler for Shipping:
Step by Step Instructions:
Read this page entirely prior to draining your boiler. These steps should be done entirely from start to finish without delay between steps.
1. Turn the machine on, let it reach normal operating temperature and/or pressure.
2. Have 2 large wide empty bowls or containers, 3 cup and 2 cup in volume handy. Place the smaller bowl or container under the brew group (Portafilter handle out) and the larger size under the hot water wand. Have both secured in place as hot water will be dispensed at hot temperature!
3. Empty the fresh water tank entirely.
4. Run the pump as you were to make coffee by lifting the lever on E61 machines (or engaging the coffee brew switch on other machines). Continue running the pump until water stops flowing from the brewgroup. One no water coming out from the brewgroup, pull the Lever all the way down (or turn off the brew switch) and immediately turn OFF the main power switch of hte machine.
5. Disconnect the machine from the electricity.
6. Without delay, open the hot water dispensing valve half way and let it drain until hot water stops flowing completely. Caution: hot water coming out from hot water wand may splash, keep away!
7. Once water stops flowing out from the hot water wand, shut off the valve.
Let machine cool completely before packing it. Leave steam valve slightly open prior to packing. Machine is now ready for shipping.
I was also about to suggest checking the Brewtus google group, but saw you posted there (
http://groups.google.com/group/brewtus/browse_thread/thread/d58738e7ad94186e#) and have completed the repair without issues. Congrats!
