Replacing an Ulka pump
Hey Guys-
So I just replaced the vibratory pump on my La Valentina. It was very straight forward, but I feel like there is something I missed. Now when I switch it on, it does not draw any water and the pump just makes a humming sound like it is struggling. I tried opening the steam valve and that did nothing. Is there some kind of priming I am supposed to do; could I have crossed some wires? I was not able to find any good pictures or instructions on how to do this correctly. As of now, my machine is simply a decoration.
Thanks,
-John
Thanks,
-John
- allon
Did you replace it with a different pump, or the same pump? Yes, I know that the subject says "Ulka", but it also says "replacing", and you don't say what you replaced it with; I could assume that you replaced it with an Ulka, but I hate to assume.
Fluid-o-Tech pumps, in particular, require a diode be placed in-line on the power.
Other than that, you could certainly try priming the pump and see if that helps get it going.
LMWDP #331
As stated above... Same or different pump..
In addition to the electrical; the output fitting can be a plastic OR a brass. Either way, they have a one way valve in the end. Have seen some users, change fittings that use a longer thread as party of a rebuild and replacement of old parts.
Thus when all assembled, the fitting goes to deep and compresses / smashes the valve and thus it no longer works as it should...
Ability is nothing without opportunity. - Napoleon Bonaparte
So I replaced what I think was a 40 watt Ulka with a 52 Watt EAX5 Ulka. It was my understanding that this one would work fine. So what do I do to prime the pump anyway?
Priming the pump is mainly about filling the entire line leading up to the pump with water. Vibratory pumps don't have much draw with air in the line. I would try carefully pouring some water into the line with it raised above pump level (or maybe using a dropper/baster). It should be just a matter of pulsing the pump on/off and adding water. Careful not to run your pump dry more than about 10 seconds at a time to prevent overheating.
Your symptoms sound very similar to what happens when I let my tank run dry.
matt
- erics
- Supporter ★
The La Valentina SHOULD BE fitted with an air release/priming valve attached to the pump and thus you should not NEED to prime anything.
Please provide some X-rated pics of your machine.
If the pump is simply humming(?), that is exactly symptomatic of what Allon described but the diode is built-in to the Ulka pumps as compared to being a "mandatory accessory" with the Fluid-o-Tech pumps.
Are you the original owner? Send me an email and I will send you the parts catalog.
