erics wrote:Yes - The brew pressure gage is reading brew boiler pressure so I would loosen one of the connections at either end of the gage and take a reading then.
Of course, Eric means for you to turn off the machine, let it cool down, and drain the brew boiler before you disconnect anything.
Disconnecting the tube at the gauge end might be a good test for a vapor lock or some sort of flexible blockage in the tube, but unfortunately the tube can't be disconnected at that end. It's soldered to the gauge.
I'm not sure there's any value in disconnecting the tube at the boiler end beyond what you would see if you simply drain the boiler. You might be able to see and clear a blockage at the very end of the tube, but if it's further down the tube you won't be able to see it and won't be able to clear it.
Given that the tube is soldered to the gauge, a blocked tube pretty-much requires replacing the entire assembly.
Again, my understanding is that the kind of failure you're seeing is pretty common with this type of gauge. When I get around to it, I'll disassemble the defective gauge I took out of my GS/3 and see if I can determine what caused it to fail.
