The contacts on my pressurestat are going bad. I can get a replacement for $117 but I've seen Sirai pressurestats for around $80.
Should I install original equipment, or will the Sirai work just as well? Will it be pre-adjusted or will I need to adjust it after it's installed? Are the fittings generally the same size?
TIA for any advise.
Gordy
