Replaced parts on my 7 year old La Marzocco GS3 - Page 2
- Peppersass
- Supporter ❤
I didn't mention my brain box falling apart because I've removed and opened/closed mine many times, which hastens the deterioration. Users who haven't had leaks and don't do mods probably won't have problems with the brain box falling apart.AssafL wrote:LM should do a special deal on all the plastic boxes. The display/keyboard, the drain, and the brain. They all fall apart after a few years in the heat....
I don't know why they recommend these things, I simply know from experience that if you use silicone based lube on silicone o'rings/seals they deteriorate (swell/soften) and you should use Petrolium Jelly (or similar). Silicone based lubes are fine for rubber. Viton is not a silicone based rubber and generally tolerates hydrocarbons OK, so Petrolium or silicon based would be fine. Of course you need to be careful as a lot of parts sold as Viton are not Viton, so it may be safer to always use a silicone lube in case.AssafL wrote:What about Viton?
Also - in the thread about Cafelat Silicone Group Gaskets Paul Pratt recommended using Dow (which is Silicone based). I was intrigued by that.
I think that anywhere inside the GS3 - Dow or Superlube should be used. No Petroleum (I am saying this from - shamefully admit - experience).
If you doubt what I say, simply look it up or talk to any friends who do scuba diving.
- AssafL (original poster)
DaveC - I don't disagree. I know this from Pneumatic brakes which can suffer the same catastrophic failures that (I guess) a scuba diver can encounter.
With lubes you have the o-ring type, medium chemistry, and lubrication chemistry. All three should be completely impervious to each other.
My GS/3 is old - serial number around 310. I've replaced most of the check valves, upgraded the vacuum breaker, dried out the brain box, and fixed various leaks and hisses with thread sealer. I did not upgrade the s-tube, as I couldn't disassemble enough plumbing to get at it (those nuts and tubing are soft!).
And yet, I can't stay ahead of its minor issues. I have to run about 6 cups of water through he hot water spout every other week to keep the steam boiler from over-filling. Electronic glitches continue. But it still mostly works.
At this point, it needs either professional service (including a new brain box) or retirement. Where does one go for a 60,000 mile service on a GS/3? I bought the machine from Chris Coffee, which is a 2 1/2 hour drive (and I don't own a car). But there must be good espresso machine service in NYC - even La Marzocco specialists, right? I know this is a very hands-on crowd, and I've learned a lot by following your extremely helpful and detailed advice, but it's time to call in a pro. Any suggestions?
Many thanks,
Matt
Many thanks,
Matt
Matt - My guess is any technician that services shops can service your machine. I would gladly try to help but I am too far away (Israel is more than 2 hours drive from Chris" Coffee .
Why does your machine overfill? Can only happen if the board is underwater or a check valve is stuck open. Did you figure out what is causing it? If it still works, you don't need a replacement board. Even if the board has issues, it is repairable. Unless the Atmel is fried, you should be able to get more years out of it.
BTW - There are very few fittings on the LM for which a thread sealer would help (eg the milk frothing tip can use PTFE sealer) so my guess is either the fittings are not well aligned, ithey aren"t sufficiently tightened or you are not tightening using two spanners.
Matt - searched back to the last issue when you were stabilizing the machine - seemed like the RTC Battery was the only issue you had - that is a welded 2032 battery. They are less than a buck....
What you must figure out is why it overfills. That is concerning since erratic behavior many times indicates a short. Either water or something else. The sensor just touches the water and the water shorts it to ground. For it not to work, something is messing with the pull-up.
Assafl,
I'm guessing it's either another failed check valve, or the lack of the upgraded s-pipe (which includes an extra check valve). The issue I had last time with intermittent error displays has returned, even though I've made sure that no new water is leaking inside - I went through a whole warmup, use, and cool down cycle with the sides off and didn't see any moisture. After my last cleaning of the main board, the problem went away for a while.
I needed thread sealant when I upgraded the vacuum breaker. Even teflon tape wasn't preventing a constant hiss. I did get a set of thin wrenches so I could use two when tightening.
I completely believe that I can fix the bleeding into the steam boiler, and I can live with it the way it is, I was just wondering if I could get a major service and get the machine back closer to spec. (And I wouldn't mind the newer drip tray - that original one is awful!)
Thanks, as always, for your advice and help,
Matt
Matt
Matt - since the error displays went away when you dried and cleaned the board - and now they are back - it means the board is probably being contaminated.As Dick warned in the other thread - your board is at risk.
You may not see the leak: For example the leak may be near the steam tank, and evaporates. But when the machine is turned off, and cools down a bit, the leak no longer evaporates and works its way along the cable to the controller. There are always signs like crusty deposits, verdigris or black oxidation, or something similar. I've even used thin tissue paper and a flashlight for find a leak.
Is what is being called the OPV here the same thing that La Marzocco calls the Safety Valve in their parts catalog (p.33 Item 4)? I suspect so but just want to make sure. I traced a sputtering steam release into the tray to it so I assume that means it is failing and needs replacement.
You mentioned sputtering in the tray - that is unlikely to be the OPV. More likely it is item 14 - the vacuum breaker. It has a relatively short(er) life as it keep sputtering boiling water (as it closes) which leave a layer of mineral deposits - which accumulate over time and eventually prevent it from sealing well (it will continue to hiss and sputter but never fully seal).
As to your question: Yes - item 4 is indeed the OPV. If the steam boiler pressure increases above the OPV pressure - the OPV will release the excess pressure. Note that is doesn't have to be runaway thermals to get the OPV to pop. A stuck open fill valve or stuck open check valves in a plumbed in machine will cause the mains pressure (many times 3 bar or more) to drive the OPV open - at that point the OPV becomes a gusher and is one of the reasons that a plumbed in machine should also be connected to the drain.
The main difference between the OPV and the vacuum breaker is that the vacuum breaker is open and closes at a specific steam pressure. An OPV will open above a specific pressure to relieve excess pressure. When both are used in the context of a steam boiler, the rated pressure needed to close the vacuum breaker will be always lower than the working pressure, whereas the rated pressure needed to open the OPV will always be higher than the working pressure.
