grong wrote:I used Norton sandpaper, 220 grit, by hand, and was through the thin chrome and into brass very quickly. Then I worked through some minor pitting, and down to a smooth polished bowl. I finished up with a polish of 400 grit, and the bowl seems very smooth.
I should probably do the same to the spout, but that chrome looks like it is fully plated. Anybody else do this?
Ken Fox wrote:I honestly believe that this is absolutely crazy, and I don't care who has recommended it.
Crazy like a fox?
But seriously, the thing about removing the chrome plating on your PF is that the effect is easily tested, if you have two PFs (one with, one without) and a means to keep them both hot (two group machine, etc).
But there's another issue that I don't understand, and I could use the help of you, Ken, and the other gurus on HB. Any tips for removing the chrome on a bottomless portafilter?
