by orphanespresso on Sun May 29, 2011 12:48 am
To remove or not to remove, that is the question...if said asbestos is tight, and stained not, with no failure of adhesion (tapping with rapping stick yields not a sickly hollow sound), if flakes are notable in their blessed absence and surface seems as a smoothe skin like the crust of peasant bread, then let it be, as the pain beset upon the workman in the needed process of boiler removal from the nesting frame of Pasquini, alas may be more the bother than the gain.
But flakes or stains or hollow rappings, adhesion failed, or balding patches (most often on the aging dome) then be cautious as the errant fibre, once disturbed may penetrate the orb or lung of master maid or passing stranger and thus disturb the peacefulness of the manor home. A cause for worry concern and hurry to rid the kitchen nest of this foul and onerous pest.
So damp or wet or under water, stripped with knife of putty, reveals the gleaming brass....the throbbing pulsing heart of this noble beast, reveals the seams of manufacture, laid bare now the solder, the dark and woeful patches, much like a chicken plucked. The foul asbestos now lays vanquished, is ragged and bagged all tightly knotted or buried in some deep dark hole away, so far away, from fragile humanity.
the end
