I recently came into a Gaggia Classic Coffee machine, and have been in the process of restoring it. I took the whole machine apart and cleaned any scaling and deposits with white vinegar then sealed it up tight with the proper gaskets, sealant, etc.
The problem I'm faced with now is the body. It's an older Classic Coffee, so it's nickel-plated carbon steel. It has begun to rust. I've tried sanding blocks, and dremels, but they work so slow, and I don't see great results (especially as it strips the nickel). Stripping the nickel will just lead to more rust, thanks to the noble qualities of carbon steel versus the nickel. I've considered stripping the body chemically (muratic acid bath) and then replating the body with nickel, but it's quite costly. I've also considered using Rust-oleum like products, but I worry about the paint being so close to potable water (as the reservoir for water has an open top, with the rusted metal directly over it).
Any ideas on how to treat the rust, and keep the body in service? Price is important for me as well (poor college student who happens to love espresso, bad mix). Thank you so much for your time folks!
Wally
