by Rosscopico0 on Sat Jan 16, 2010 4:22 pm
Hi Greg!,
Thanks for your input, Im honored to have 2 of the biggest hitters in the game weighing in on my thread!
I figure I will be doing the mods in stages & testing the machine in a commercial environment (my work) & having the work fb/70 as a backup in case.
I plan to do the mods in a few stages.
Currently the first one is the brew boiler PID (since the original brew boiler thermostat was damaged during removal).
Im wondering with the Piero caps mod, since I will be later replacing a lot (possibly all) of the control systems, if it is worthwhile converting the machine to an EE & doing the EE piero cap mod (Im assuming I will need EE group heads?)
Also as I want to install a pressure profile system, I intend having a failsafe system in place.
I figure that since a gear pump can run on either a PWM or varying voltage, I can run the microcontrolled profile system in parallel with a basic potentiometer controlled system, that I can set the pump pressure on & simply have inline switches on each system. So if the microcontrolled system fails, I can switch it off & switch on the basic system, adjust my pressure via the potentiometer if necessary & continue operating the machine.
Later on down the line, Im thinking of possibly using 2 gs/3 boilers ( 1 for each group) & running 2 PID controllers with separate profiling systems to use different coffees on the same machine, but thats a fair time away!
