I need either a rebuild kit or a source of specific pump parts for the Ulka EP5. Or...even someone who recycles the Ulka EP5 parts. A great web-page detailing the internal pump parts is at:
http://ulkapumprepair.blogspot.com/2008...-page.htmlThe
piston that I need is the silver cylinder-ish part between the two large springs in the top half of this picture:
http://www.myschiffman.org/cg/pump_parts.jpgI've been unable to find such a source. The Ulka EP5 seems to be VERY common in espresso machines and I'm actually surprised a re-build kit isn't readily available.
In my case all I need is a replacement piston and it's ludicrous for people to have to spend US$50-60+ for the whole pump and basically throw-away otherwise perfectly good parts.
All I've found for sale are complete assembled pumps at higher than necessary prices and usually with excessive shipping prices. (e.g. I know the Ulka EP5 could be mailed for about US$4 using 1st Class Mail. I buy similar size and weight electronic components shipped like that all the time)
In my case simple dis-assembly and cleaning did not help much. Everything in the Ulka EP5 pump is in GREAT shape...except for the piston. The piston is very badly corroded due to being constantly immersed in water (plus the design puts dissimilar metals in contact with each other in water). I think the rust-promoting design is common to most of the machines out there.
A re-build kit (e.g. for a carburetor) generally contains many or all the replaceable internal parts of a mechanical item. In the case of the Ulka EP5 pump, a universal re-build kit would most likely contain the o-rings, the rubber bob on the spring, the nylon ball, the springs, and the piston. Those are the parts most likely to wear out, become deformed, rust, deteriorate, etc.
Re-build kits are almost always cheaper than buying the complete manufactured item (even at refurbished prices), or if they aren't cheaper they are usually made with better parts (design or materials). They're usually also easier and cheaper to ship and have less impact on the environment.
Example of a rebuild kit for a "steam valve" on another espresso machine
http://www.precisiontamp.com/product/MZ...L165K.htmledit to add:
My Krups XP2010 is a bit under 3 years old and has been used almost every day to make 1 to 3 servings.
Note: the Krups XP2010 came with a 1 year limited warranty, but from the user manual
"The limited warranty does not cover coffee makers that fail or work poorly due to scale."
