Random spurts of hot water from steam wand
Postby timothyst.j on Thu Jun 17, 2010 1:55 pm
Has anyone else felt that their pitcher of milk was in danger of being flooded with hot water from a steam wand that shoots out hot water and steam? When I start my machine up in the morning, I let it heat up for about an hour before I use it. Lately, I've had to purge the steam wand for about 10 seconds before I can get consistent steam without random spurts of hot water. But, even after I do that, I still get these random spurts of hot water shot into my milk.
I always purge before and after each steaming, and I soak the tip of the wand for about 20 minutes at the end of using it.
Any tips?
Tim
timothyst.j
Postby Bob_McBob on Thu Jun 17, 2010 2:02 pm
This usually means the boiler is overfilled. On a machine with autofill, the probe level may be set too high, or reading too high because of scale.
Chris
LMWDP #295
Bob_McBob
Postby HB on Thu Jun 17, 2010 3:07 pm
To elaborate on Bob's point, scale can slowly build up on the water level sensor probe, resulting in a progressively higher water level. Eventually this leads to wet steam. Chris' Coffee FAQ How to properly replace a liquid level sensor probe provides good removal instructions, caveats, and photo.
Postby timothyst.j on Thu Jun 17, 2010 3:37 pm
thanks
timothyst.j
Return to Espresso Machines
