Rancilio Silvia's dramatic end? - Page 2
Postby Randy G. on Tue Feb 22, 2011 12:47 pm
jlhsupport wrote:Your boiler has a blue tint to it. This means it has overheated significantly at least once. ... Also, regarding the flash, inspect all wires, even the ones that run down to the pump for any worn off insulation. .....
I wonder if that is just a result of mixed lighting..? But look at the tan wire that crosses over the heating element's terminal. That looks fairly close and should be routed away from there (maybe up and over). That is the sort of thing to look for. With the machine unplugged, run your hand down all the wires you can and feel for any damage to the insulation.
Espresso! My Espresso!
Randy G.
Previous
Return to Espresso Machines
