Rancilio Silvia steam thermostat turns off at 130°C?
Postby kog on Thu Sep 09, 2010 10:39 am
Hi,
Interested to know if other finding their Silvia steam thermostat is turning boiler off at 130c.
I have fitted an auber PID (which seems to be working fine). It is showing steam thermostat clock off at 130c consistently. I had understood it should stay on until 140c.
I brew at 102 and this works great with beans I use.
I was suspicious of the steam thermostat and got a replacement - fitted the replacement and exactly the same 130c cut off point.
The thermostat click boiler back in again at 120c.
Any ideas would be much appreciated.
Many thanks
kog
Postby Louis on Thu Sep 09, 2010 11:13 am
I have an Auber PID that also control steam temp. I have it set to turn the heater on at <=139°C and off at >=140°C (user configurable, I think this was the out-of-the-box settings). The original button steam thermostat on the boiler is not used in this setup but I can hear it click off long before the PID reaches 140°C. I would need to check to confirm the exact temperature, but I would say it is around 125-130°C.
Louis
Postby kog on Thu Sep 09, 2010 11:34 am
thanks. I had a feeling that the 130c might be closer to the norm, although all documentation I've seen says the steam themo is rated for 140c.
kog
Return to Espresso Machines
