As there was a lot of posts on Silvia's being set to incorrect pressure I decided make a pressure gauge to test it. I decided to make my gauge with an ability to allow water flow so as to not incorrectly measure a blind filter pressure which I understand could be quite a bit higher.
Below is what I put together using a liquid filled gauge (thanks to the previous work of bobroseman) see link: Help with La Cimbali Jr.
I allowed for water flow of 60ml in 25sec. This gave a pressure reading of 9.8 bar. I subsequently reduced this to 9.0 bar. I don't know if there was any recognizable difference but the first 2 shots I puled looked good and no channeling or squirting using my naked PF (I had some previously).
What may be of interest to some is that when I closed the valve to stop all water flow I did not measure any increase in pressure - that is once the system was closed (like a blind filter) the gauge did not record any increase in pressure over the pressure recorded for water flow of 60ml in 25sec. When the value was opened to allow for increased water flow the pressure did decrease.
I tested this further by taking about my setup and installing only a 90 degree angle off the PF directly to the gauge. This read the same pressure as when recording with the valve setup (open for 60ml in 25sec).
Has anyone else tried this? I know there are several people who were recording their pressure with a blind filter and then wondering whether this was accurate - if my machine is anything to go by it would seem that there is no difference.
