I got it from a coffee shop via ebay, for $400. Unfortunately it's really hard to score a good deal in Canada due to the lack of density and in my area (Calgary), we're a bit behind larger metropolitan centers in terms of espresso style coffee. Anyway, I definitely will post some rebuild photos. It was a complete teardown to the frame and because I wanted to keep this cheap, I didn't powder coat, just sprayed it with spray paint. The only other improvement made was the addition of an insul-brite boiler insulation blanket. I bought enough material from a sewing shop ($9), made a nice velcro seam for removal and because it's kind of a random-fiber material, just cut out holes around the necessary protrusions.
At this point in the rebuild, I have the group headers in, the pump installed and the boiler installed, with the insulation on. No piping at all. During the rebuild, I treated the whole thing to a citric acid bath, twice over. I had tons of scale in the boiler and the exchangers and everything was nasty, especially the gicars which are now clean but weren't dosing correctly when I bench-tested it before the teardown. I have new gaskets for the boiler main gasket and the heating element gasket (both teflon) and have treated the group headers to new gaskets and will also replace the o rings on the gicars and the o rings on the group header valves.
So along to my question... I removed the heating element to give it a dip in the acid bath too, keeping all the wiring intact, just dipping the elements in the bath which worked very well. Unfortunately, I have a connection issue, best described through the diagram below:
When I was taking the assembly apart, I unscrewed part number 31 from part 33. Although it doesn't show it well in the diagram, the stainless tube (part 29) is actually not continuous and part 32 is, according to the rancilio parts diagrams, a teflon tube which covers the transition. My little teflon tubing (about 3/8" or 8 mm long) actually split along it's length as well. I know the tubing (part 32) looks more like some kind of pressure sealing gasket but it's not, it's just a tube that fit snugly over the two sections of stainless piping to line them up. I can't find a replacement part anywhere but I was actually thinking of using teflon tape to replace this, packing the whole joint pretty tightly before screwing parts 31 and 33 together.
Any thoughts on this? I'm assuming the teflon tape will seal the entire cavity up well but it's not ideal because of the high temperatures at the heater. Any advice would be welcome.
