by erics on Mon Jul 25, 2011 9:27 pm
Under normal circumstances, when you power up ANY hx machine, the water level is contracted. This initiates a fill action - the pump comes on and the fill solenoid valve opens simultaneously. The pump operates for a couple of seconds and all is well.
In your case (assuming I'm correct), the solenoid valve fails to open but the pump runs - your brew pressure gage should read ~ 9.0 bar during this unfortunate event.
While not necessarily obvious to you, there can be a couple of reasons why the solenoid valve does not open:
a. no power
b. failed solenoid coil
c. stuck valve
These are, for sure, possibilities but the most common cause is a stuck valve fixed by my previous post.
