A few notes on the installation...
1) As indicated by Chris, you really need an INSANELY LONG philips head screwdriver to tighten the outer front mount. I was able to get at it with just a regular VERY long screwdriver (at a bad angle, though) by removing the GICAR box (one screw).
2) The video shows Chris pre-tightening the inner front mount, but inserting the first screw into the outer one. Not sure if that was by design or a result of video editing. If I had known that it would be trouble tightening the mounts from the top afterwards, I would have made a cardboard template of the hole patterns in the bottom case and pre-tightened 3 of the 4.
3) Keep a rag over the pump openings when you tilt the machine. I had a few drops spill out and it was enough to get my GFI outlet to trip (even with the machine off) until I could dry up the bottom shell with some air.
4) Don't forget to turn your water back on before running the pump!
Also, on this question...
sweaner wrote:Chris, nice video. Is there a way to tell which mounts one has without removing things?
...I bet if you remove one of the mount screws from below you could tell. The bad ones are silver and have blocked holes (see 6:06 in the video) and the good ones are brass-like and don't have blocked holes. It amazing how the bad ones transfer that vibration throughout the machine and the good ones don't. They appear to be identical except for the closed holes (maybe that design kept the screws from fully seating). Both have the top and bottom nuts separated by column of rubber. Strange, but anyhow, the machine is blissfully quiet now. Chris, thanks again!
