I recently picked up a used 2005 Quickmill Anita. I have been doing a lot of reading on the pages here in trying to isolate the problem(s) I'm having. The amount of information on this site is mind boggling. I really appreciate it! No way I would have been as comfortable with the work I've done thus far, without it.
So on to my troubles:
Upon pulling my first shots with the machine (post 45 minute warm up) I noticed that the temperature of the espresso didn't seem right. Luke warm really. I checked the water coming out of the group with a thermocouple, and the single portafilter in place. It was ~160 F. Hmmm. So I let the machine continue to warm up for another hour, and checked the water temperature again. This time it was ~210 F. Seemed like an unusually long warm up, but at least it got up to temp. I pulled a couple shots, with at least 45 seconds recovery between them, and checked the temperature again. ~145 F? So it appears the temperature of the water coming out of the group is dropping very quickly.
After a fair bit of googling HX machines, and the troubles with them, I decided it was time to have a look at the machines mushroom (much thanks to a post on this site detailing the procedure!). Here is a picture of what I found (sorry about the image quality, but hopefully you can see the little green/blue bits):
Sure enough there was some scale. I'm not sure if scale could be the culprit, but seems like it couldn't help. In my google searching I came across a lot of material on the descaling process. After reading, then re-reading, then printing, then re-reading again
While letting the machine warm up (prior to draining the boiler) I also noted the machines behavior a bit more closely, hoping to possibly pick up any final clues to the brew temp issue:
After ~5 minutes warming up, the water in the boiler begins to boil, and the vacuum breaker seals. A few moments later the boiler pressure settles at 1.2-1.25 bar. Seemed reasonable. Shortly there after though the group pressure goes from 0 to 2.25 bar? Seemed strange? And for the rest of the warm up cycle that's the state the machine stayed in.
After about an hour, I turned off the machine and unplugged it. I opened up the hot water valve and drained the boiler.
Now to remove the heating element, and get a look. Or not... As much as I wanted to, I couldn't get the heating element to budge. And I mean I really tried. To the point of having the machine casing flex. Nothing. So for now the heating element has won. Is anyone aware of any tricks to get them out? I had a thought that it might just be scale buildup making it difficult to remove? I'd really like to see inside the boiler for a before/after comparison. But I dunno, the element seems pretty stuck...
So barring any suggestions you all might have, I'm thinking It's time to run the HX + boiler through a descale? Any thoughts/suggestions?
Thanks so much!
-Nate
