If the Hx on Anita is about 100 ml. then there is room in there for just about two shots if you don't have to flush at all on consecutive shots. If you want to pull several consecutive shots for guests and 1.5 minutes isn't enough time to recover then I ask if there is a way using the grouphead thermometer to determine when is a good time to pull the next shot without flushing?
Geoffrey -
It gets pretty complicated if you think about hx volume and shot volume in the same sentence because, while true that the hx volume is ~ 100 ml, there is also the tubing and small volume of water circulating in the grouphead.
Let me assume your Anita would follow the graph I posted earlier. That graph depicts a long flush of Anita which, by itself, reduces the grouphead temperature ~ 12 F. The remaining drop and inherent increase is all on the shoulders of the thermosyphon system. If you did absolutely nothing over the next 15-20 minutes, the system would restore itself to the point at which you started - 212 F. It would be very similar, if not identical, to the time required for this same temperature change during initial machine warmup.
Initiating your first shot at 197-198 F after the initial long flush (> 2 minutes) would give you a nice shot. Doing a short screen flush after the shot allows for the next shot about 2-1/2 minutes after you started the first shot. This 2nd shot would also be initiated at a grouphead temp of 197-198 F. Depending upon the number of guests I was preparing drinks for, I would opt for preparing the baskets ahead of time.
