Upon pulling a shot, the pump will run up to 9.5 bar then drop down to 3 bar along with a "humming" noise.
I've tentatively traced it to a bad Klixon thermal fuse, as the pump runs fine when the fuse is bypassed.
That's not the issue at hand though.
Anita is 2 years old and the boiler's insulation has cracked and is falling off. It seems to also coat everything inside the machine with a residue of some sort.
My question here is - can I just take all of the insulation off the boiler and run it bare without any problems? I've read through the different insulation threads and there isn't really a cohesive school of thought on whether or not insulation is needed.
