Quickmill Andreja Premium steam not as dry as before
afan
#1: Post by afan »
Folks, The steaming my Andreja seems not as dry as before and is a bit not too steady.
Any idea?
Alex
LMWDP #327
SCAA Q-Grader
samuellaw178
#2: Post by samuellaw178 »
Sounds like a symptom that the water level in the boiler is too high. How old is the machine? If it's new to you, you could try looking at the water probe. If it's sticking too far up, you can try pushing it in a little and see if that solves the problem.
If it's old, probably a descaling is in order because scale might cover and affect the water probe function. So the water in the boiler fills higher. Then the steam would be relatively wet and sputter every once a while.
afan (original poster)
#3: Post by afan (original poster) »
It is round 4 to 5 yrs, how do I know the water level?
Alex
LMWDP #327
SCAA Q-Grader
Admin
#4: Post by HB »
Eric Svendson has posted this diagram elsewhere:
From What is the purpose of a vacuum breaker valve
You could remove a fitting and measure with a wooden dowel rod. That said, if it's been 4 to 5 years, the water level may have been slowly creeping up over time as scale formed on the water probe. Chris' Coffee FAQ #27 How to properly replace a liquid level sensor probe explains how to remove/replace one.
#5: Post by afan (original poster) »
Thx, will look in that.
LMWDP #327
SCAA Q-Grader
