Quickmill Andreja Premium - Boiler leak
Hi everyone
I bought a Quickmill Andreja Premium. After about 2 months of regular use (2-3 espressi/day) I am experiencing a rather nasty problem. 5 minutes after powering up the machine, you can clearly hear a constant hiss coming from the top of the machine. I opened the machine and discover a small hole (!) at the top of the boiler (see image, small black dot surrounded by white stuff). You can clearly see water coming out of it during the heating up process. Now, this sounds like a seriuos issue to me. Any advice/similar experiences from Andreja owners?
Further Info:
- I use tap water (not sure about hardness)
- During the first two months of use everything seemed to be ok
- Coffee quality is unaffected by the problem
Thank you!
Further Info:
Thank you!
- cannonfodder
Could be a gasket leaking but if it is only two months old, take it back and get a replacement.
- HB
- Admin
It doesn't look like a gasket leak to me; more like a weld pinhole. I can't find the discussion, but I thought there were reports of a batch of Quickmill boilers suffering from pinhole leaks. Eric Svendson (erics) would probably remember...
- erics
- Supporter ★
I agree w/ Dan - it looks like a pinhole in the silver solder joint where the hx upper female fitting is attached to the boiler. If this is a NEW machine originally purchased by you (2 months ago) it should be a valid warranty item.
If this is a used machine that you simply purchased two months ago, there are several ways this can (POSSIBLY) be fixed.
Thank you for your responses. It is definitely a pinhole. The machine is new and still under warranty. However I'll have to ship the machine abroad for repair (online vendor), i.e. it won't be cheap . The other option would be to let it fixed locally (soldered), but I'm somehow unconfortable with this kind of repair. If you have any link concerning discussions on defective quickmill boilers batches it would be great!
Greetings
Greetings
- erics
- Supporter ★
I would call your vendor first & discuss situation. If you feel unsatisfied after that, I would contact Quickmill directly. When I say "call", I would think a phonecall and a concurrent email would be the best course.
Keep in mind that this is holiday time (or close to it) for Italy.
